Hi everybody, I don´t know if this topic has been talked yet.
I need remove hot pixels in a batch of files at the same time in AA6. I have thought in a script, but I'm rookie in this subject. Anybody knows how to do this script?
Thanks in advance.
remove hot pixels in several files at the same time.
agudo.fyq
Re: remove hot pixels in several files at the same time.
Hi, in AA6 I suggest using a Macro instead. Using a script would be much more complicated.
At first define the Macro, use the command "Define Macro":
as a test, try the Macro manually on some images.
Then this macro can be applied on several images on disk at once, command "Apply Macro"
Select "Disk, same folder" or "Disk, selected folder" as destination.
Drag & drop the files in the "Images" box and click OK.
However if you also need to stack these images, you may just use the filter "Hot pixels" in the Extra page of Preprocessing.
agudo.fyq
Perfectly explained. It works fine. You have saved me a lot of work.
Thank you very much.
