Camera Control Setup tab - Scripts
Patrick
Post by Patrick » 13 Aug 2023, 06:51
In the Camera Control SETUP tab, can someone please explain what is the purpose of the Scripts choice?
It appears that while an existing script can be selected from the Library, there can only be one recorded?
When does such a script run?
It appears that to remove that script one must select New?
Patrick.
Re: Camera Control Setup tab - Scripts
Post by Dunmunro » 15 Aug 2023, 04:22
Patrick wrote:
13 Aug 2023, 06:51
Patrick.
See:
Help (? icon)-> scripts for a tutorial.
Scripts are saved as separate files and then loaded as needed; here's a script that I co-wrote with a friend:
viewtopic.php?f=5&t=725 (last post).
To test a script run the simulators for the required hardware.
Post by Iver » 15 Aug 2023, 04:37
click scripts, library, configure, name the script, insert the path to the saved script.
You can then execute the script by clicking on the name of the script you want to run.
Patrick
Post by Patrick » 16 Aug 2023, 07:22
Dunmunro and Ivor,
Thanks for replying.
I have created scripts so understand that part of it.
I obviously did not pose the question clearly.
As scripts can be run from the main menu Macro page, I was curious as to why the Script option was available on the Camera Control Setup page. It appeared to me to be very similar and simply User's choice?
Patrick.
Post by Iver » 16 Aug 2023, 15:39
I would assume that scripts in the macro tab would be processing scripts and camera control scripts would be scripts used during image acquisition.
Patrick
Post by Patrick » 16 Aug 2023, 23:05
Sound reasonable. Thanks
