Pixel processing in SP6
Post by fabdev » 29 Mar 2021, 03:28
Hello, as written in the post about the release of Service Pack 6, some new commands have been added, and all the "GetPixel" and "SetPixel" commands are now much faster to permit image processing and analysis in scripts.
Image.PrepareUndo
Image.Undo
Image.GetPixelR(x,y)
Image.GetPixelG(x,y)
Image.GetPixelB(x,y)
Image.SetPixelRGB(x,y,r,g,b)
"Image.PrepareUndo" stores the current image in the Undo buffer. Try for example on a grayscale image: (on a color image it will process only the green plane)
Image.PrepareUndo
cx = Image.Width
cy = Image.Height
x1 = Round(cx * 0.25)
y1 = Round(cy * 0.25)
x2 = Round(cx * 0.75)
y2 = Round(cy * 0.75)
for y = y1 to y2
  for x = x1 to x2
    v = Image.GetPixel(x,y)
    Image.SetPixel(x,y,v*1.05)
  next x
next y
Image.Update
Pause(2)
Image.Undo
The typical speed is approx 1 megapixel/sec for such filters. If you need to work on a multi-megapixel image you may consider implementing a preview in a selected rectangle:
Image.PrepareUndo
x1 = Image.Rectangle.X1
y1 = Image.Rectangle.Y1
x2 = Image.Rectangle.X2
y2 = Image.Rectangle.Y2
if x1 = x2 then
  Message("Please select a rectangle")
  end
end if
for y = y1 to y2
 for x = x1 to x2
 next x
next y
Image.Update
or a mask (grayscale example):
Image.PrepareUndo
if not Image.Mask.Active then
  Message("Please select a mask")
  end
end if
x1 = Image.Mask.X1
y1 = Image.Mask.Y1
x2 = Image.Mask.X2
y2 = Image.Mask.Y2
for y = y1 to y2
 for x = x1 to x2
   m = Image.Mask.GetPixel(x,y)
   if m <= 0.5 then continue
   Image.SetPixel(x,y,v*1.05*m)
 next x
next y
Image.Update
smoothed mask: (grayscale)
Image.PrepareUndo
  end
end if
x1 = Image.Mask.X1
y1 = Image.Mask.Y1
x2 = Image.Mask.X2
y2 = Image.Mask.Y2
for y = y1 to y2
 for x = x1 to x2
   if m <= 0 then continue
   vOri = Image.GetPixel(x,y)
   vNew = vOri*1.1
   v = vNew*m + vOri*(1-m)
   Image.SetPixel(x, y, v)
 next x
next y
Image.Update
use the commands GetPixelR, G, B to process a color image. For example: (desaturation)
Image.PrepareUndo
if x1 = x2 then
  end
end if
for y = y1 to y2
 for x = x1 to x2
   r = Image.GetPixelR(x,y)
   g = Image.GetPixelG(x,y)
   b = Image.GetPixelB(x,y)
   lum = r*0.3 + g*0.6 + b*0.1
   Image.SetPixel(x, y, (r+lum)*0.5, (g+lum)*0.5, (b+lum)*0.5)
 next x
next y
Image.Update
Re: Pixel processing in SP6
Post by Rudi » 11 May 2021, 14:25
This is great.
Is it possible to define a two dimensional array in the scripting language?
I've tried: dim(640,480) dim(640;480) dim(640:480) dim(640)(480) (...and many more), but with no luck.
I need to store the image bits in an array in order to subtract one image from another in a script.
Post by fabdev » 12 May 2021, 14:10
Hi Rudi,
it's not possible, but just like in C it's possible to use a mono-dimensional array to represent the image, then the item can be addressed as X + Y*Width . For example for coordinate x = 100 and y = 50:
w = 640
h = 480
Dim arr(w*h)
x = 100
y = 50
arr(x + y*w + 1) = 65000
print arr(x + y*w + 1)
Every array item will take 32 bytes by the way.
to subtract a given image to several images via scripts it's also possible to use: Image.Macro(1) , after having defined the Macro #1 as Subtract Image.
Post by Rudi » 13 May 2021, 04:05
Thanks Fabio. I will proceed with the one dimensional array. Just wanted to ask first ;-)
