Normalize in macro
einari
Normalize in macro
Post by einari » 23 Oct 2025, 10:44
Is it possible to avoid approving the normalization file in macro?
I'm doing animation macro and it's kind of tedious with lots of frames.
Re: Normalize in macro
Post by fabdev » 24 Oct 2025, 14:06
Hi, which normalization exactly ? May you post a screenshot of the commands of the macro ?
einari
Post by einari » 01 Dec 2025, 17:13
Like this
Post by fabdev » 03 Dec 2025, 03:42
To solve, open the image "2025-10-21...." before launching the Macro.
Macro with images as parameters, require that the image is already opened inside Astroart (they will not be opened automatically from disk).
However in SP3 it will be sufficient to select the image once. For the moment you can double-click to select quickly the image each time.
If you instead need to change every time the image to be used for normalization, consider Editing the macro (right click) and select the image for that sequence (already opened in Astroart).
einari
Post by einari » 03 Dec 2025, 11:15
Thak you!
