This method is the slowest but it's the most precise, so it's recommended only for fixed setups, or if North is not visible.
See for example: https://canburytech.net/DriftAlign/DriftAlign_1.html
The script allows to move the telescope by hand or by GOTO to the two testing position, which are close to the celestial equator at South and at East.
In the script there's a parameter, "waitTime" that must be set according to the precision you want to achieve, the default is 60 seconds. For extremely precise pointing it must be increased to 200-300 but then the whole procedure becomes very slow, so I recommend high values only for a fixed mount.
' ******* Polar alignment via Declination Drift *******
' Before using this script verify that plate solving is
' correctly set up, with a precision of 2%
' Verify also that the Observatory Coordinates and the
' PC time is correct.
' The telescope must be tracking.
' Connect the camera and verify the focus.
lon = Observatory.Longitude
lat = Observatory.Latitude
exposure = 10.0
waitTime = 60 ' Time to wait for drift
r = InputButton("Which axis do you want to align?", "Left-Right", "Up-Down", "EXIT")
Pause(0.5)
confirm = CRLF + "Press OK when done."
if r = "Left-Right" then AlignLeftRight
if r = "Up-Down" then AlignUpDown
end
sub AlignLeftRight
ra,de = AltazToEquat(182, 45, lon, lat)
if not PrepareTelescope(ra,de) then
coords = CRLF + "Approx. " + RaToString(ra) + " " + DecToString(de)
Message("Point manually the telescope at South, altitude approx. 45° " + coords + confirm)
end if
while true
TakeExposure
if not WidePlateSolve(ra,de) then ShowFail
ra,de = Image.RaDec
WaitForDrift
TakeExposure
ra2,de2 = Image.RaDec
error = Round((de2-de)*3600*10)
hint = ""
if error < 0 then hint = "Move the mount Clockwise (telescope towards West)."
if error > 0 then hint = "Move the mount Anticlockwise (telescope toward East)."
msg = "The error is: " + Str(error/10) + " arcseconds. " + hint
r = InputButton(msg, "Continue", "I'm satisfied")
if r <> "Continue" then break
end while
end sub
sub AlignUpDown
ra,de = AltazToEquat(90, 45, lon, lat)
Message("Point manually the telescope at East, altitude approx. 45° " + coords + confirm)
end if
while true
TakeExposure
ra,de = Image.RaDec
WaitForDrift
TakeExposure
hint = ""
if error > 0 then hint = "Move the polar axis Up (toward Zenith)."
if error < 0 then hint = "Move the polar axis Down (toward Horizon)."
end while
end sub
sub PrepareTelescope(ra,de)
r = InputButton("Automatic(GOTO) or manual movement of the telescope?", "Automatic", "Manual", "EXIT")
if r = "Automatic" then
Telescope.Goto(ra, de)
Telescope.Wait
return true
end if
if r = "Manual" then
Pause(0.5)
return false
end if
Script.Stop
end sub
sub TakeExposure
Image.Close
Camera.Start(exposure)
Camera.Wait
end sub
sub ShowFail
Warning("Cannot plate solve image.")
Script.Stop
end sub
sub WaitForDrift
for i = waitTime to 0 step -1
cls
print i
pause(1) ' Waiting for drift ....
next i
end sub
function WidePlateSolve(ra,de)
if Image.PlateSolve(ra, de, 6, 4.0) then return true
if Image.PlateSolve(ra, de, 6, 15.0) then return true
offs = 14.5
for j = -1 to 1
for i = -1 to 1
if Image.PlateSolve(ra+i*offs, de+j*offs, 6, 15.0) then return true
next i
next j
return false
end function
