Arrays?
Forum_2015
Arrays?
Post by Forum_2015 »
I could not find any documentation regarding arrays (either numeric or string). Do they exist?
Forum_2015
Re: Arrays?
For character arrays, you may use strings:
filters = "LRRGGBB"
For i = 1 to Len(filters)
  Print filters[i]
Next i
for string arrays, you may use the { } syntax, see the example:
Menu / Demos / Basic 4
for generic arrays, the standard Dim keyword is supported, but this feature is currently experimental (5.42 or newer). It works well, but there are two limitations: all arrays are global, whole arrays cannot be passed as function parameters.
Some examples:
Dim arr(10)
For i = 1 to 10
  arr(i) = i*i
Next i
For i = 1 to 10
  Print arr(i)
Next i
arrays will be actually released as "lists", the following example is quite nice:
Dim arr = {4, 5*5, "hel"+"lo", 0.5, Sqr(64)}
For i = 0 to 4
  Print arr(i)
Next i
Re: Arrays?
Post by Rudi » 15 Aug 2022, 05:17
Forum_2015 wrote:
07 Dec 2018, 22:07
filters = "LRRGGBB"
  Print filters[i]
Next i
Some examples:
Dim arr(10)
For i = 1 to 10
  arr(i) = i*i
Next i
For i = 1 to 10
  Print arr(i)
Next i
For i = 0 to 4
  Print arr(i)
Next i
How do one get the dimension of an array? Don't want to hardcode size in the script I am creating.
For i = 0 to arr.Dim()     <==== error, also tried "Dim", "Len()", "Len", .... and many more options
  Print arr(i)
Next i
[/quote]
Re: Arrays?
Post by fabdev » 16 Aug 2022, 16:47
the function to get the length of an array is: UBound(array)
For more information see the paragraph "Types and variables"
Re: Arrays?
Post by Rudi » 17 Aug 2022, 07:26
Thanks - that worked out fine.
