calibration frame
Morten Lerager
calibration frame
Post by Morten Lerager » 13 Jun 2022, 17:04
Hi
Trying to figure out how to make Master frame.
In preprocess I can load my dark and flats.
I don't load any Lights, resulting in master frame.
But.... How about the settings. Normal I use some filtre. Hot pixels and some other.
Are the filtre bypassed for calibration frame.
Or is it OK to use them...?
Asi294mc. AA8.
Re: calibration frame
Post by fabdev » 14 Jun 2022, 17:03
Hi Morten, to view and save the master dark frame and flat field, enable the option "Show master ..." in Preprocessing. Actually to just create a master it's even simpler to use the Images box, so that you could add some other processing, for example you could correct the dark frames of the flat fields.
Morten Lerager
Post by Morten Lerager » 14 Jun 2022, 18:44
Thank you Fabio
I'll give it a try.
Asi294mc. AA8.
