Compare 16 vs. 32 Bit
Morten Lerager
Post by Morten Lerager » 13 Jun 2022, 06:34
Hi'
My subs are 16bit fits
The stacked fit file are 32 bit
How do i easily compare ADU's on this to image.
I would also like to compare standard deviation.
Thank's Morten Lerager
Edit: I will try to pixel edit to value 70000. It could be a work around to
get the file in 32bit.
Edit Edit: Ohh, a better work around would be to stack only the One sub.
....If this will do the trick, to convert it to 32Bit
Edit Edit Edit: Ok now. Stacking a single sub wont change it to 32bit.
Pixel edit to a V70000 will change to 32bit without scaling. So AA automatic change
på 32bit. only if needed.
The "error" was my bad. I had a single sub with a background standard deviation reading 37.3
After preprocessing 20 x subs the same standard deviation was 143 ....No so funny.
The if I change Sigma + Sum to Average the reading is 6.5 :)
Asi294mc. AA8.
Re: Compare 16 vs. 32 Bit
Post by fabdev » 14 Jun 2022, 16:59
Hi, to average (or sigma+average) a sequence of 16 bit images, consider the option "Keep result in 16 bits", since the flat field correction can indeed exceed the 16 bit range if a saturated star (65535) is present.
To compare quickly the dynamic of several images, open the Statistics Window for one image, then set it to "Unlocked" mode, then switch to other images.
To compare only a subregion, select a rectangle or a mask over an image, and click "Real time" in the context menu of the statistics. Then move the region, for example with CTRL + mouse drag.
Morten Lerager
Post by Morten Lerager » 14 Jun 2022, 19:00
Thank you for all your great tips & trick.
And to keep it 16 bit seems to me, the way to go from here.
Asi294mc. AA8.
