Goto Plate Solve issues
Re: Goto Plate Solve issues
Hi Droogie ?, I just want to encourage you to spend the time to perfect this technique. I do it using scripts and it works great and is a huge time saver. I set up on my patio so I probably don't break my setup down as far as you need to. It looks like you need to find a way to reposition your scope and camera more accurately. Maybe try putting some blue painters tape on the scope and camera and draw a line across the two pieces to realign to. Good luck!
Hi Iver.
Thanks for the tip I will give that a try.
Also please can you paste a copy of the script that you use in this thread?
I am only using a custom text file which I use for plate solving. Here is an extract from the text file that I load into the Telescope Control, GOTO tab. Obviously these RA & DEC co-ordinates have be gathered from previous images I have taken.
"NGC869-DoubleCluster" 02 20 01.9 +57 13 21
"M16-Eagle-Nebula" 18 18 53.0 -13 30 25
"M31" 00 41 57.7 +41 21 18
"IC1805-Heart-Neb" 02 31 11.0 +61 34 13
Hello
take a look at "Observationa manager 9", this magnificent piece of software has a visual interface but generates scripts for AA5 and 6. (https://groups.yahoo.com/neo/groups/AA5 ... s/messages) and the youtube channel (https://www.youtube.com/channel/UCYx7T1 ... HMKndDQucQ)
I watched a couple of videos on this. The Script Runner looks interesting as it contains a script which informs you how much out your RA & DEC are. Though I am not sure if there is any ability to do anything about this other than move the mount manually as it describes, maybe you could automate this? The main problem is that I cannot find the application to download it.
The Yahoo group also requires me to be a member but I cannot see where I can apply to become a member?
https://www.youtube.com/watch?v=2WZiRuQe93E
Hi Droogie, here is what I do! Once the scope is polar aligned and aligned with the ski I do a goto to my target and take a 10 second exposure. Then I run this short script.
x = Telescope.Ra
Y = Telescope.Dec
nstars = 5
Image.FindCoordinates(x,y,nstars)
if Image.Ra = 0 then message ("Solve failed") then end
Telescope.SyncTo(Image.RA,Image.DEC)
The scope is now accurately synced to the target. Next open one of the subs you want to match the alignment to and run this script.
x = Telescope.Ra
Y = Telescope.Dec
nstars = 5
Telescope.Goto(Image.Ra,Image.Dec)
If your camera and scope are still oriented close to the way they were when you took the first set of subs your new images should stack fine with your first set.
x = Telescope.Ra
Y = Telescope.Dec
nstars = 5
x = Telescope.Ra
Y = Telescope.Dec
nstars = 5
Thanks Iver. I will have a look into this further. Weather is looking poor again so not sure when I can try this...
When I initially run the first "Synch to" script I get Solve failed. This is I suspect because I have not entered the targets name. Where / when do I do this? I guess I can manually plate solve first then run the Synch script, if I do this then it works. (via the Simulator)
My script gets the target ra and dec from the scope so if you are not connected to the scope connect to the scope stimulator and goto the target with the simulator or already have the image solved.
