AA9 and starlight xpress camera connection problem
jacobson
Post by jacobson » 09 May 2025, 02:36
I have tow starlight xpress cameras , a truis procamera m25c and a truis sx825 mono. If I try to use the cameras with their ascom drivers the following occurs; when I get to the camera chooser and click properties the entire program hangs. The "windows" are not moveable. To escape I go to alt control escape to click off AA9. Sitting there and active is the camera properties little page, sx camera setup. If I leave that on and restart AA9 , setup, Ascom Camera it will recognize the truis camera. If I click on the properties page ( the saved one) all works. why is this annoying problem?? thanks jacobson
Re: AA9 and starlight xpress camera connection problem
Post by fabdev » 10 May 2025, 03:27
Maybe their dialog window gets displayed in the background, below the Astroart window, you may close it pressing ALT+F4 or ESC.
Another solution is to move the Astroart window away from the center of the screen before clicking Properties.
jacobson
Post by jacobson » 11 May 2025, 23:40
well you did it again, thanks. moving the windows around before clicking properties works. thank you again! charles jacobson
