Strange Behavior with ZWO ASI294MM camera
cardanoc
Post by cardanoc » 04 Oct 2021, 16:51
Hello
I open Astro Art 7 and
a) opened up the "Camera Control 7.0" window
b) clicked on the dropdown box and selected "Video"
c) clicked the "Setup" button
d) clicked on "ASI 174MM Camera"
e) clicked the "Connect" button
f) clicked "OK". The video Grabber window closed.
g) Changed my exposure to 1 sec.
h) Click "Start".
e) an image appeared and I was able to save it.
I repeated these steps with a different camera.
d) clicked on "ASI 294MM Pro Camera"
h) Click "Start".
e) It took the 1 sec exposure, and the "Download..." message appeared.
Three minutes later it was still trying to download.
When I clicked on the any part of the window, the entire screen went black and the system froze.
I had to reboot.
I checked the ZWO website. All of my drivers are up to date.
Re: Strange Behavior with ZWO ASI294MM camera
Post by Dunmunro » 05 Oct 2021, 17:07
cardanoc wrote:
04 Oct 2021, 16:51
Hello
h) Click "Start".
h) Click "Start".
I had to reboot.
I think you should be selecting 'ASCOM' instead of 'Video'.
cardanoc
Post by cardanoc » 05 Oct 2021, 18:18
Hi
When I select ASCOM, none of my cameras show up in the list.
I do have the latest version of ASCOM and drivers.
Post by Iver » 05 Oct 2021, 18:36
Make sure you have the ASCOM platform installed, the ZWO ASCOM driver and the Astroart ASCOM plugin from the Astroart website installed.
Post by Dunmunro » 05 Oct 2021, 18:41
cardanoc wrote:
05 Oct 2021, 18:18
Hi
You've installed the latest version of the ASCOM platform?
https://ascom-standards.org/
When the ASCOM platform is installed and you install the ASI294MM specific drivers (and Astroart's ASCOM interface), then you'd select ASCOM and the ASI294mm will appear as a camera option.
cardanoc
Post by cardanoc » 11 Oct 2021, 17:08
When I choose ASCOM, the only that shows up in the dropdown menu is "Camera V2 Simulator" and "simulator".
cardanoc
Post by cardanoc » 12 Oct 2021, 16:01
ZWO "just" (i.e., 10/8/2021) came out with a new ASCOM driver.
I installed it.
Everything works fine.
Thanks to all of you.
Conrad
