Is astroart 5 or 6 meant to work with canon 40D or 5D mkii, both work with APT and Nebulosity without problems. My Skyris 274 works with astroart 5 and 6 so I believe my setup is ok. Each time I connect the popup says "EOS Capture / Remote Shooting not found", have tried with and without canon EOS Utility running. Not sure what I should try next with regards to Astroart.
Any advice would be appreciated.
regards
Paul
Capture with EOS 40D and 5D mkii
Re: Capture with EOS 40D and 5D mkii
Hello, check the option "Camera name in Remote Shooting" in the driver. See the PDF manual of the driver for more information. You may also try the new native Canon driver, which does not require Remote Shooting.
Thank you Facavi, the updated driver sorted my problem, now both canons work, thanks again
