FITS Header coordinates
Patrick
Post by Patrick » 04 Sep 2025, 01:53
Are the ra and dec coordinates as read from the mount and recorded in the FITS header - for the beginning of the exposure?
Patrck.
Re: FITS Header coordinates
Post by fabdev » 04 Sep 2025, 19:31
no, they are read from the telescope when the image is downloaded.
The only data that is recorded at the start of the exposure is the time.
Patrick
Post by Patrick » 04 Sep 2025, 22:05
Thank you.
Patrick
Patrick
Post by Patrick » 05 Sep 2025, 22:59
Might it be possible to include the Sidereal Time property read from the mount as a Write to FITS header option?
Patrick.
Post by fabdev » 07 Sep 2025, 21:31
Yes, but why "read" from the mount ? Instead it can be automatically calculated from the other data.
Is this to be read by a software or a human? (there is no a standard FITS keyword for LST, someone uses decimal (10.423242) others h-m-s (10:23:56)).
For humans it could be interesting to express it as mid of exposure.
P.S. for a given image here is a script to show the sideral time:
 lst = SideralTime(Observatory.Longitude, Image.JD)  ' or just Image.MidJD
 print "Sideral time = "; RaToString(lst)
Patrick
Post by Patrick » 08 Sep 2025, 00:22
I noted ‘read from the mount’ as merely a suggestion to pssibly match your explanation.
Very happy to have the option to calculate and record the local sidereal time in the image header using other data - at download. This also makes the time stamp the same (at download i.e. the end of the exposure) for all such data?
I do spectra analysis using IRAF and IRAF tasks accept the st value as a sexagesimal strung with twodecimals in the seconds (a separate email sent).
Regards.
Patrick.
