Astroart 9 SP4
Astroart 9 SP4
Post by fabdev » 05 May 2026, 20:19
Hello, a new minor version of Astroart 9 is available, see: https://www.msb-astroart.com/
Version 9.0 SP4 - May 5, 2026
* New feature. Blind dithering for sequences.
* New feature. 3D graph with antialiasing and zoom.
* New feature. Image resize with option for gamma correction.
* New feature. Script commands for controlling the star atlas.
* New feature. Script commands for querying bright stars.
* New feature. Drag&drop of scripts into the editor.
* New feature. Scripts can be run from the command line.
* Improved. Documentation formatting and content.
* Improved. RGB demosaic (debayer) is faster.
* Improved. Visualization of big images is faster.
* Improved. Optical deformations are corrected with more precision.
* Improved. Date and time formatting for live annotations.
* Improved. Progress for preprocessing is shown on the Windows taskbar.
* Improved. Two SX filter wheels can be connected in two instances.
* Improved. More keyboard shortcuts.
* Bug fix. Some annotations were not displayed correctly.
* Bug fix. Some PGC galaxies were not visible in the atlas.
* Bug fix. Some deformed images were not mapped correctly in the atlas.
Dithering can now be performed without autoguiding, by sending short pulses to the telescope: this is useful if your mount is "too" precise on tracking, to avoid using the same pixels in all subs of a sequence.
The 3D graph is drawn with anti-aliasing and can be zoomed: The resize command has options for duplicating the image and performing gamma correction:
Live annotations, useful for making animations, now support custom date/time formats: Demosaic RGB, visualization and other commands are faster thanks to new SIMD AVX code which processes 8 pixels at a time.
