The center plate
The center plate
In script functions, for example Image.EstimateRaDec what is defined as "the center plate"?
Patrick.
Patrick.
Re: The center plate
Hi Patrick,
"center plate" is a geometrical definition of the coordinates (x/2,y/2) where x and y are the numbers of the pixels of the sensor.
Regards.
Alessandro Maitan
Regards.
Alessandro Maitan
Alessandro,
Thank you. Very clear.
Patrick.
Patrick.
Hello again,
Further to the response above,Is the central plate the center of the sensor, or perhaps could it be also the center of an image or a rectangle?
What is the function of the Center plate selectors in the Astrometry window?
Patrick.
Patrick.
Hello Patrick,
the answer to the first question is yes, it could be also the center of an image. According to my understanding the always a geometrical definition (i.e. an image, either cropped or not, is centered at coordinates x and y).
The center plate selection is not in the Astrometry window but you can always select it with View -> Grid.
I hope to have understood your question.
Regards
Alessandro
Regards
Alessandro
Alessandro
Thanks for the answer to the first question.
The Center plate details I referred to is seen if i follow the Tutorial on Plate Solving (AA8 SP4 User's Guide p. 16) then select Astrometry from the Tools menu.
Patrick.
Patrick.
Hello Patrick,
in the Astrometry panel of the Tool Menu the item "Center Plate", as far as I have understood, indicates the precision in pixel (0.5 is the suggested precision) of the position of the center plate once the Astrometry calculation have been done. It is indicated by a red inclined cross in the image you are analysing.
Regards
Alessandro
Regards
Alessandro
Alessandro,
Thanks for the response.
This all seems outside my level and is best left alone by me.
Patrick
Patrick
